REST API reference
Update a shadow copy set
Updates a shadow copy set to modify its properties or configuration based on your requirements. This operation is typically used when adjustments to existing shadow copies are needed to align with changes in data protection or recovery strategies.
HTTP method and endpoint
PATCH /protocols/cifs/shadowcopy-sets/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates a Shadowcopy set
uuid
string
path
True
Storage shadowcopy set ID.
Request Body
Name Type Description
keep_snapshots
boolean
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy set.
Example request
  "keep_snapshots": "",
  "svm": {
    "name": "svm1",
  "uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: 200, Ok
Status: Default, Error
string
svm
name
string
uuid
string
shadowcopy_set
keep_snapshots
boolean
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
