REST API reference
Update a shadow copy set
Updates a shadow copy set to modify its configuration or refresh its contents as needed.
HTTP method and endpoint
PATCH /protocols/cifs/shadowcopy-sets/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates a Shadowcopy set
uuid
string
path
True
Storage shadowcopy set ID.
Request Body
Name Type Description
keep_snapshots
boolean
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy set.
Example request
  "keep_snapshots": "",
  "svm": {
    "name": "svm1",
  "uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: 200, Ok
Status: Default, Error
string
svm
name
string
The name of the SVM.
uuid
string
shadowcopy_set
keep_snapshots
boolean
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
