Update a shadow copy set
Updates a shadow copy set to modify its existing configuration. Use this operation to keep your data backups accurate and aligned with your requirements.
HTTP method and endpoint
PATCH /protocols/cifs/shadowcopy-sets/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates a Shadowcopy set
Learn more
uuid |
string |
path |
True |
Storage shadowcopy set ID. |
Request Body
| Name | Type | Description |
keep_snapshots |
boolean |
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation. |
svm |
uuid |
string |
The universally-unique identifier of the storage's shadow copy set. |
Example request
"keep_snapshots": 1,
"svm": {
"name": "svm1",
"uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262196 |
The 'svm' field is not supported in the body of a PATCH request. |
href |
string |
_links
svm
name |
string |
uuid |
string |
shadowcopy_set
keep_snapshots |
boolean |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
