Update the NDMP mode
Updates the NDMP mode to configure the node-scope mode for data management operations. This is typically used to modify settings for NDMP-related tasks.
HTTP method and endpoint
PATCH /protocols/ndmp
Introduced in
ONTAP 9.7
Related ONTAP commands
system services ndmp node-scope-mode
Learn more
Request Body
| Name | Type | Description |
_links |
mode |
string |
Indicates whether NDMP is in node-scoped or SVM-scoped mode. |
Example request
"mode": "string"
Status: 200, Ok
_links |
mode |
string |
"mode": "string"
Status: Default, Error
href |
string |
_links
cluster_ndmp_properties
_links |
mode |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
