Update the NDMP mode
Updates the NDMP mode to configure or modify the data management settings for your storage system. This is typically used when adjusting backup and recovery operations.
HTTP method and endpoint
PATCH /protocols/ndmp
Introduced in
ONTAP 9.7
Related ONTAP commands
system services ndmp node-scope-mode
Learn more
Request Body
| Name | Type | Description |
mode |
string |
Indicates whether NDMP is in node-scoped or SVM-scoped mode. |
Example request
"mode": "string"
Status: 200, Ok
mode |
string |
"mode": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
65601575 |
NDMP node-scope mode is not supported in FSx for ONTAP. |
href |
string |
_links
cluster_ndmp_properties
mode |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
