REST API reference
Update the NDMP mode
Updates the NDMP mode to configure the Network Data Management Protocol settings according to your requirements. This is typically used to manage backup and restore operations effectively.
HTTP method and endpoint
PATCH /protocols/ndmp
Introduced in
ONTAP 9.7
  • system services ndmp node-scope-mode
Learn more
Request Body
Name Type Description
mode
string
Indicates whether NDMP is in node-scoped or SVM-scoped mode.
Example request
  "mode": "string"
Status: 200, Ok
mode
string
  "mode": "string"
Status: Default
ONTAP Error Response codes
Error code Description
65601575
NDMP node-scope mode is not supported in FSx for ONTAP.
68812807
NDMP node-scope mode is not supported on this platform.
string
cluster_ndmp_properties
mode
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
