REST API reference
Update the NDMP mode
Updates the NDMP mode to configure the data management protocol settings for network data management operations.
HTTP method and endpoint
PATCH /protocols/ndmp
Introduced in
ONTAP 9.7
  • system services ndmp node-scope-mode
Learn more
Request Body
Name Type Description
mode
string
Indicates whether NDMP is in node-scoped or SVM-scoped mode.
Example request
  "mode": "string"
Status: 200, Ok
mode
string
  "mode": "string"
Status: Default
ONTAP Error Response codes
Error code Description
65601575
NDMP node-scope mode is not supported in FSx for ONTAP.
string
cluster_ndmp_properties
mode
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
