REST API reference
Update the NFS connected-client cache settings properties
Updates the properties of the NFS connected-client cache settings to manage how client connections are cached. Use this operation to modify cache configurations according to your specific network and performance requirements.
HTTP method and endpoint
PATCH /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Request Body
Name Type Description
client_retention_interval
string
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days.
enable_nfs_clients_deletion
boolean
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed.
Example request
  "client_retention_interval": "string"
Status: 200, Ok
Status: Default, Error
string
nfs_clients_cache
string
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
