REST API reference
Update NFS connected-client cache settings properties
Updates the properties of NFS connected-client cache settings to optimize client caching behavior as needed.
HTTP method and endpoint
PATCH /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Request Body
Name Type Description
client_retention_interval
string
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days.
enable_nfs_clients_deletion
boolean
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed.
update_interval
string
The time interval between refreshing the connected-clients cache. The minimum is 1 hour and the maximum is 8 hours.
Example request
  "client_retention_interval": "string",
  "update_interval": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
3277172
The value for "client_retention_interval" must be between 12 and 168 hours or its equivalent in days, minutes or seconds.
3277170
The "client_retention_interval" must be set to a value which is a multiple of 12 hours or to its equivalent in days, minutes or seconds.
string
nfs_clients_cache
string
boolean
update_interval
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
