Update NFS connected-client cache settings properties
Updates the properties of NFS connected-client cache settings to optimize client caching behavior as needed.
HTTP method and endpoint
PATCH /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Request Body
| Name | Type | Description |
client_retention_interval |
string |
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days. |
enable_nfs_clients_deletion |
boolean |
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed. |
update_interval |
string |
The time interval between refreshing the connected-clients cache. The minimum is 1 hour and the maximum is 8 hours. |
Example request
"client_retention_interval": "string",
"update_interval": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3277172 |
The value for "client_retention_interval" must be between 12 and 168 hours or its equivalent in days, minutes or seconds. |
3277170 |
The "client_retention_interval" must be set to a value which is a multiple of 12 hours or to its equivalent in days, minutes or seconds. |
href |
string |
_links
nfs_clients_cache
string |
boolean |
update_interval |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
