Update NFS connected-client cache settings properties
Updates the properties of the NFS connected-client cache settings to optimize client caching behavior. Use this endpoint to modify cache settings as needed for improved performance and resource management.
HTTP method and endpoint
PATCH /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Request Body
| Name | Type | Description |
client_retention_interval |
string |
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days. |
enable_nfs_clients_deletion |
boolean |
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed. |
Example request
"client_retention_interval": "string"
Status: 200, Ok
Status: Default, Error
href |
string |
_links
nfs_clients_cache
string |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
