Update the Vscan scanner-pool configuration for an SVM
Updates the Vscan scanner-pool configuration for an SVM to manage server, user, and role settings efficiently within your network environment.
HTTP method and endpoint
PATCH /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Introduced in
ONTAP 9.6
Usage notes
Updates the Vscan scanner-pool configuration of an SVM.
Important notes:
Along with servers and privileged-users, the role of a scanner-pool can also be updated with the cluster on which a scanner-pool is allowed.
If role is specified and cluster isn't, then role is applied to the local cluster.
Related ONTAP commands
vserver vscan scanner-pool modify -
vserver vscan scanner-pool apply-policy -
vserver vscan scanner-pool privileged-users add -
vserver vscan scanner-pool privileged-users remove -
vserver vscan scanner-pool servers remove -
vserver vscan scanner-pool servers add
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
cluster |
privileged_users |
array[string] |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role |
string |
Specifies the role of the scanner pool. The possible values are:
servers |
array[string] |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
svm |
Example request
"cluster": {
"name": "cluster1",
"privileged_users": [
"cifs\\u1",
"cifs\\u2"
"role": "string",
"servers": [
"1.1.1.1",
"10.72.204.27",
"vmwin204-27.fsct.nb"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027258 |
The specified cluster_name does not exist |
10027256 |
The specified cluster_uuid does not exist |
10027257 |
The specified cluster_name and cluster_uuid are valid but belong to different clusters |
10027248 |
Scanner-pool updated successfully but failed to apply the specified role |
10027107 |
The list of privileged users or list of servers specified is empty |
10027108 |
The list of privileged users specified contains an invalid entry |
10027063 |
Attempting to modify a scanner-pool on an administrative SVM with a data SVM |
href |
string |
_links
cluster_reference
_links |
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster |
privileged_users |
array[string] |
role |
string |
servers |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
