Update the Vscan scanner-pool configuration for an SVM
PATCH /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Updates the Vscan scanner-pool configuration of an SVM.
Important notes:
Along with servers and privileged-users, the role of a scanner-pool can also be updated with the cluster on which a scanner-pool is allowed.
If role is specified and cluster isn't, then role is applied to the local cluster.
Related ONTAP commands
vserver vscan scanner-pool modify -
vserver vscan scanner-pool apply-policy -
vserver vscan scanner-pool privileged-users add -
vserver vscan scanner-pool privileged-users remove -
vserver vscan scanner-pool servers remove -
vserver vscan scanner-pool servers add
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
name  |
string  |
path  |
True  |
Request Body
| Name | Type | Description |
cluster  |
privileged_users  |
array[string]  |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role  |
string  |
Specifies the role of the scanner pool. The possible values are:
servers  |
array[string]  |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
Example request
  "cluster": {
        "href": "/api/resourcelink"
    "name": "cluster1",
  "privileged_users": [
    "cifs\\u1",
    "cifs\\u2"
  "role": "string",
  "servers": [
    "1.1.1.1",
    "10.72.204.27",
    "vmwin204-27.fsct.nb"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027258  |
The specified cluster_name does not exist  |
10027256  |
The specified cluster_uuid does not exist  |
10027257  |
The specified cluster_name and cluster_uuid are valid but belong to different clusters  |
10027248  |
Scanner-pool updated successfully but failed to apply the specified role  |
10027107  |
The list of privileged users or list of servers specified is empty  |
10027108  |
The list of privileged users specified contains an invalid entry  |
10027063  |
Attempting to modify a scanner-pool on an administrative SVM with a data SVM  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
cluster_reference
_links  |
name  |
string  |
uuid  |
string  |
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster  |
privileged_users  |
array[string]  |
role  |
string  |
servers  |
array[string]  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
