REST API reference
Update a volume efficiency policy
Updates a volume efficiency policy to modify its settings according to your storage management needs.
HTTP method and endpoint
PATCH /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
  • volume efficiency policy modify
uuid
string
path
True
Volume efficiency policy UUID
Request Body
Name Type Description
comment
string
A comment associated with the volume efficiency policy.
duration
integer
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0.
enabled
boolean
Is the volume efficiency policy enabled?
qos_policy
string
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations.
schedule
schedule
start_threshold_percent
integer
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule.
type
string
Type of volume efficiency policy.
uuid
string
Unique identifier of volume efficiency policy.
Example request
  "comment": "string",
  "duration": 5,
  "enabled": 1,
  "qos_policy": "string",
  "schedule": {
    "name": "daily"
  "start_threshold_percent": 30,
  "type": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
6881341
Specified schedule not found.
6881344
Failed to queue specified job.
6881348
This operation cannot be performed because the specified policy is owned by the cluster admin.
6881349
Policy name is not valid.
6881362
Threshold percentage cannot be less than 1 percent.
6881433
For "{{0}}" type policy, "{{1}}" duration is not supported.
6881435
Only a policy of type "threshold" can set the "start-threshold-percent" attribute.
6881436
For a policy of type "scheduled", a valid "schedule" is a required attribute.
6881438
For "{{0}}" policy, modification of attributes is not allowed.
6881474
Duration cannot be null.
6881475
Duration is not valid.
6881476
Duration cannot be less than 1 hour.
6881477
Duration cannot be more than 999 hours.
string
schedule
name
string
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced.
svm
name
string
The name of the SVM.
uuid
string
volume_efficiency_policy
comment
string
duration
integer
enabled
boolean
qos_policy
string
schedule
schedule
integer
type
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
