Update a volume efficiency policy
Updates a volume efficiency policy, adjusting its settings to optimize storage space and performance.
HTTP method and endpoint
PATCH /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
volume efficiency policy modify
Learn more
uuid |
string |
path |
True |
Volume efficiency policy UUID |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the volume efficiency policy. |
duration |
integer |
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0. |
enabled |
boolean |
Is the volume efficiency policy enabled? |
qos_policy |
string |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations. |
schedule |
start_threshold_percent |
integer |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule. |
type |
string |
Type of volume efficiency policy. |
uuid |
string |
Unique identifier of volume efficiency policy. |
Example request
"comment": "string",
"duration": 5,
"enabled": 1,
"qos_policy": "string",
"schedule": {
"name": "daily"
"start_threshold_percent": 30,
"type": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Code
| Error Code | Description |
6881341 |
Specified schedule not found. |
6881344 |
Failed to queue specified job. |
6881348 |
This operation cannot be performed because the specified policy is owned by the cluster admin. |
6881349 |
Policy name is not valid. |
6881362 |
Threshold percentage cannot be less than 1 percent. |
6881433 |
For "{{0}}" type policy, "{{1}}" duration is not supported. |
6881435 |
Only a policy of type "threshold" can set the "start-threshold-percent" attribute. |
6881436 |
For a policy of type "scheduled", a valid "schedule" is a required attribute. |
6881438 |
For "{{0}}" policy, modification of attributes is not allowed. |
6881474 |
Duration cannot be null. |
6881475 |
Duration is not valid. |
6881476 |
Duration cannot be less than 1 hour. |
6881477 |
Duration cannot be more than 999 hours. |
href |
string |
_links
schedule
name |
string |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume_efficiency_policy
comment |
string |
duration |
integer |
enabled |
boolean |
qos_policy |
string |
schedule |
integer |
type |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
