Update a volume efficiency policy
Updates a volume efficiency policy to modify its settings, ensuring that the policy aligns with your storage optimization goals.
HTTP method and endpoint
PATCH /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
volume efficiency policy modify
Learn more
uuid |
string |
path |
True |
Volume efficiency policy UUID |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the volume efficiency policy. |
duration |
integer |
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0. |
enabled |
boolean |
Is the volume efficiency policy enabled? |
qos_policy |
string |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations. |
schedule |
start_threshold_percent |
integer |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutually exclusive of the schedule. |
type |
string |
Type of volume efficiency policy. |
uuid |
string |
Unique identifier of volume efficiency policy. |
Example request
"comment": "string",
"qos_policy": "string",
"schedule": {
"name": "string"
"type": "string",
"uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
918702 |
The specified operation on the volume efficiency policies endpoint is not supported on this platform. |
6881341 |
Specified schedule not found. |
6881344 |
Failed to queue specified job. |
6881351 |
Policy name is too long. |
6881352 |
Policy name is not valid. |
6881362 |
Threshold percentage cannot be less than 1 percent. |
6881433 |
For "threshold" type policy, "schedule and duration" is not supported. |
6881435 |
Only a policy of type "threshold" can set the "start-threshold-percent" attribute. |
6881438 |
For "inline-only and auto" policy, modification of attributes is not allowed. |
href |
string |
_links
schedule
name |
string |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced. |
svm
name |
string |
uuid |
string |
volume_efficiency_policy
comment |
string |
duration |
integer |
enabled |
boolean |
qos_policy |
string |
schedule |
integer |
type |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
