Update a volume efficiency policy
PATCH /storage/volume-efficiency-policies/{uuid}
Introduced In: 9.8
Updates a volume efficiency policy.
Related ONTAP commands
volume efficiency policy modify
Learn more
uuid  |
string  |
path  |
True  |
Volume efficiency policy UUID  |
Request Body
| Name | Type | Description |
comment  |
string  |
A comment associated with the volume efficiency policy.  |
duration  |
integer  |
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0.  |
enabled  |
boolean  |
Is the volume efficiency policy enabled?  |
qos_policy  |
string  |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations.  |
schedule  |
start_threshold_percent  |
integer  |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule.  |
type  |
string  |
Type of volume efficiency policy.  |
uuid  |
string  |
Unique identifier of volume efficiency policy.  |
Example request
  "comment": "string",
  "qos_policy": "string",
  "schedule": {
    "name": "string"
  "type": "string",
  "uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
6881341  |
Specified schedule not found.  |
6881344  |
Failed to queue specified job.  |
6881351  |
Policy name is too long.  |
6881352  |
Policy name is not valid.  |
6881362  |
Threshold percentage cannot be less than 1 percent.  |
6881433  |
For "threshold" type policy, "schedule and duration" is not supported.  |
6881435  |
Only a policy of type "threshold" can set the "start-threshold-percent" attribute.  |
6881438  |
For "inline-only and auto" policy, modification of attributes is not allowed.  |
href  |
string  |
_links
schedule
name  |
string  |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced.  |
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
volume_efficiency_policy
comment  |
string  |
duration  |
integer  |
enabled  |
boolean  |
qos_policy  |
string  |
schedule  |
integer  |
type  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
