Create a new BGP peer group for VIP
Creates a new BGP peer group for VIP, enabling multipath-routing when multiple paths are available for VIP interfaces. This helps manage network traffic more efficiently by automatically configuring routing paths.
HTTP method and endpoint
POST /network/ip/bgp/peer-groups
Introduced in
ONTAP 9.7
Usage notes
Multipath-routing is turned on cluster-wide automatically if the peer group being created results in multiple paths being available for an existing or future VIP interface.
Required properties
name- Name of the peer-group to create. -
ipspace.nameoripspace.uuid-
Required with local.interface.name to identify a local interface
Optional when local.interface.uuid is specified
local.interface.uuidorlocal.interface.name-
Required when specifying an existing local interface.
local.interface.name,local.ipandlocal.port-
Required to create a new local interface.
peer.address- IP address of the peer router
Default property values
If not specified in POST, the following default property values are assigned:
is_next_hop- false
Related ONTAP commands
network bgp peer-group create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ipspace |
Either the UUID or name is supplied on input. |
local |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address. |
name |
string |
Name of the peer group |
peer |
Information describing the router to peer with |
state |
string |
State of the peer group |
uuid |
string |
UUID of the peer group |
Example request
"ipspace": {
"name": "exchange",
"local": {
"interface": {
"name": "lif1",
"ip": {
"address": "10.10.10.7",
"netmask": "24"
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "bgpv4peer",
"peer": {
"state": "string",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376963 |
Duplicate IP address is specified. |
1966133 |
Since masking an address with a netmask represents an entire IP subnet, the masked and unmasked IP addresses cannot be the same. |
1966267 |
IPv6 addresses must have a prefix length of 64. |
1966269 |
IPv4 addresses must have a netmask length between 1 and 32. |
1967082 |
IPspace name and UUID must match if both are given. |
1967155 |
The specified local.port.name does not match the location.port.name for the specified local.interface. |
1967156 |
The specified local.port.node.name does not match the location.port.node.name for the specified local.interface. |
1967157 |
The specified local.port.uuid does not match the location.port.uuid for the specified local.interface. |
1967158 |
The specified local.interface.name does not exist in the associated IPspace. local.ip.address and local.ip.netmask are required to create a new LIF. |
1967159 |
local.interface does not support management-bgp service. |
1967160 |
The specified local.interface.name does not match the specified interface name of local.interface.uuid. |
1967161 |
The specified local.interface.uuid does not exist in the specified IPspace. |
1967162 |
Either local.interface or local.ip and local.port are required to specify a local LIF. |
1967163 |
The specified local.port.name does not match the specified port name of local.port.uuid. |
1967164 |
The specified local.port.node.name does not match the specified node name of local.port.uuid. |
1967165 |
The specified local.port does not exist. |
1967166 |
ipspace.uuid or ipspace.name must be provided with local.interface.name together to identify a LIF. |
1967167 |
Internal error. Failed to update BGP configuration for node. Retry the command, if necessary. |
1967168 |
Internal error. Failed to create a VIP port for IPspace on node. Retry the command, if necessary. |
1967169 |
Internal error. BGP configuration changed during the operation. Retry the command, if necessary. |
1967170 |
Internal error. VIP port configuration changed during the operation. Retry the command, if necessary. |
1967171 |
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary. |
1967172 |
Peer group could not be updated because IPspace does not exist. Retry the command, if necessary. |
1967173 |
The specified local.ip.address does not match the address for the specified local.interface. |
1967174 |
The specified local.ip.netmask does not match the netmask for the specified local.interface. |
1967176 |
The specified local.interface.name does not exist in the associated IPspace. local.port.name, local.port.node.name, or local.port.uuid is required to create a new LIF. |
1967177 |
Internal error. Failed to access the local interface. Retry the command, if necessary. |
1967178 |
The IPv6 address specified with local.ip.address is not supported because it is link-local, multicast, v4-compatible, v4-mapped, loopback or "::". |
1967179 |
The IPv4 address specified with local.ip.address is not supported because it is multicast, loopback or 0.0.0.0. |
1967187 |
Configuring 4 bytes peer.asn requires an effective cluster version of 9.9.1 or later. |
1967188 |
Configuring peer address as a next hop requires an effective cluster version of 9.9.1 or later. |
1967189 |
The parameter peer.asn can't be zero. |
53281985 |
Internal error. Failed to update BGP peer group because BGP LIF moved during the operation. Wait a few minutes and try the command again. |
53282006 |
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address. |
53282007 |
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family. |
53282018 |
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address. |
href |
string |
_links
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip
IP information
interface
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ip
IP information to create a new interface.
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
node
name |
string |
Name of node on which the port is located. |
port
_links |
name |
string |
node |
uuid |
string |
local
interface |
ip |
IP information to create a new interface. |
port |
peer
address |
string |
Peer router address |
asn |
integer |
Autonomous system number of peer |
is_next_hop |
boolean |
Use peer address as next hop. |
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace |
local |
name |
string |
peer |
state |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
