Create a new BGP peer group for VIP
POST /network/ip/bgp/peer-groups
Introduced In: 9.7
Creates a new BGP peer group for VIP. Multipath-routing is turned on cluster-wide automatically if the peer group being created results in multiple paths being available for an existing or future VIP interface.
Required properties
name- Name of the peer-group to create. -
ipspace.nameoripspace.uuidorlocal.port-
Required with local.interface.name or local.ip.address to identify a local interface
Optional when local.interface.uuid is specified
local.interface.uuidorlocal.interface.nameorlocal.ip.address-
Required when specifying an existing local interface.
local.ipandlocal.port-
Required to create a new local interface.
peer.address- IP address of the peer router
Default property values
If not specified in POST, the following default property values are assigned:
is_next_hop- false -
peer.md5_enabled- false
Related ONTAP commands
network bgp peer-group create
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
ipspace  |
Either the UUID or name is supplied on input.  |
local  |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.  |
name  |
string  |
Name of the peer group  |
peer  |
Information describing the router to peer with  |
state  |
string  |
State of the peer group  |
uuid  |
string  |
UUID of the peer group  |
Example request
  "ipspace": {
    "name": "Default",
  "local": {
    "interface": {
      "name": "lif1",
    "ip": {
      "address": "10.10.10.7",
      "netmask": "24"
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "bgpv4peer",
  "peer": {
    "md5_enabled": 1,
    "md5_secret": "SECRET_WORD"
  "state": "string",
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376963  |
Duplicate IP address is specified.  |
1966133  |
Since masking an address with a netmask represents an entire IP subnet, the masked and unmasked IP addresses cannot be the same.  |
1966267  |
IPv6 addresses must have a prefix length of 64.  |
1966269  |
IPv4 addresses must have a netmask length between 1 and 32.  |
1967082  |
IPspace name and UUID must match if both are given.  |
1967155  |
The specified local.port.name does not match the location.port.name for the specified local.interface.  |
1967156  |
The specified local.port.node.name does not match the location.port.node.name for the specified local.interface.  |
1967157  |
The specified local.port.uuid does not match the location.port.uuid for the specified local.interface.  |
1967158  |
The specified local.interface.name does not exist in the associated IPspace. local.ip.address and local.ip.netmask are required to create a new LIF.  |
1967159  |
local.interface does not support management-bgp service.  |
1967160  |
The specified local.interface.name does not match the specified interface name of local.interface.uuid.  |
1967161  |
The specified local.interface.uuid does not exist in the specified IPspace.  |
1967162  |
Either local.interface or local.ip and local.port are required to specify a local LIF.  |
1967163  |
The specified local.port.name does not match the specified port name of local.port.uuid.  |
1967164  |
The specified local.port.node.name does not match the specified node name of local.port.uuid.  |
1967165  |
The specified local.port does not exist.  |
1967166  |
ipspace.uuid or ipspace.name must be provided with local.interface.name together to identify a LIF.  |
1967167  |
Internal error. Failed to update BGP configuration for node. Retry the command, if necessary.  |
1967168  |
Internal error. Failed to create a VIP port for IPspace on node. Retry the command, if necessary.  |
1967169  |
Internal error. BGP configuration changed during the operation. Retry the command, if necessary.  |
1967170  |
Internal error. VIP port configuration changed during the operation. Retry the command, if necessary.  |
1967171  |
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary.  |
1967172  |
Peer group could not be updated because IPspace does not exist. Retry the command, if necessary.  |
1967173  |
The specified local.ip.address does not match the address for the specified local.interface.  |
1967174  |
The specified local.ip.netmask does not match the netmask for the specified local.interface.  |
1967176  |
The specified local.interface.name does not exist in the associated IPspace. local.port.name, local.port.node.name, or local.port.uuid is required to create a new LIF.  |
1967177  |
Internal error. Failed to access the local interface. Retry the command, if necessary.  |
1967178  |
The IPv6 address specified with local.ip.address is not supported because it is link-local, multicast, v4-compatible, v4-mapped, loopback or "::".  |
1967179  |
The IPv4 address specified with local.ip.address is not supported because it is multicast, loopback or 0.0.0.0.  |
1967187  |
Configuring 4 bytes peer.asn requires an effective cluster version of 9.9.1 or later.  |
1967188  |
Configuring peer address as a next hop requires an effective cluster version of 9.9.1 or later.  |
1967189  |
The parameter peer.asn can't be zero.  |
1967192  |
Configuring peer.md5_enabled requires an effective cluster version of 9.16.1 or later.  |
1967193  |
Configuring peer.md5_enabled requires the peer.md5_secret parameter.  |
1967194  |
Configuring peer.md5_secret requires that peer.md5_enabled is set to true.  |
53281985  |
Internal error. Failed to update BGP peer group because BGP LIF moved during the operation. Wait a few minutes and try the command again.  |
53282006  |
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address.  |
53282007  |
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family.  |
53282018  |
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address.  |
53282021  |
IPsec must be enabled to use TCP MD5 in BGP sessions with a BGP peer-group.  |
53282024  |
peer.md5_secret should be 1-80 bytes.  |
53282025  |
peer.md5_secret should have an even length.  |
53282026  |
The hex format of peer.md5_secret should have only hex string starting with '0x'.  |
53282027  |
peer.md5_secret should be 1-79 characters.  |
53282028  |
peer.md5_secret supports only printable ASCII characters such as numbers, alphabets, or special characters.  |
href  |
string  |
_links
ipspace
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
ip
IP information
interface
A network interface. Either UUID or name may be supplied on input.
ip  |
IP information  |
name  |
string  |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.  |
uuid  |
string  |
The UUID that uniquely identifies the interface.  |
ip
IP information to create a new interface.
address  |
string  |
IPv4 or IPv6 address  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.  |
node
name  |
string  |
Name of node on which the port is located.  |
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name  |
string  |
node  |
uuid  |
string  |
local
interface  |
A network interface. Either UUID or name may be supplied on input.  |
ip  |
IP information to create a new interface.  |
port  |
Port UUID along with readable names. Either the UUID or both names may be supplied on input.  |
peer
address  |
string  |
Peer router address  |
asn  |
integer  |
Autonomous system number of peer  |
is_next_hop  |
boolean  |
Use peer address as next hop.  |
md5_enabled  |
boolean  |
Enable or disable TCP MD5 signatures per RFC 2385.  |
md5_secret  |
string  |
The shared TCP MD5 secret key. This can either be given as a password or hexadecimal key.  |
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace  |
local  |
name  |
string  |
peer  |
state  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
