Create a new BGP peer group for VIP
Creates a new BGP peer group for VIP, which helps establish multipath-routing automatically across the cluster if multiple paths are available for existing or future VIP interfaces. You might use this to enhance network redundancy and routing efficiency.
HTTP method and endpoint
POST /network/ip/bgp/peer-groups
Introduced in
ONTAP 9.7
Usage notes
Multipath-routing is turned on cluster-wide automatically if the peer group being created results in multiple paths being available for an existing or future VIP interface.
Required properties
name- Name of the peer-group to create. -
ipspace.nameoripspace.uuidorlocal.port-
Required with local.interface.name or local.ip.address to identify a local interface
Optional when local.interface.uuid is specified
local.interface.uuidorlocal.interface.nameorlocal.ip.address-
Required when specifying an existing local interface.
local.ipandlocal.port-
Required to create a new local interface.
peer.address- IP address of the peer router
Default property values
If not specified in POST, the following default property values are assigned:
is_next_hop- false
Related ONTAP commands
network bgp peer-group create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ipspace |
Either the UUID or name is supplied on input. |
local |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address. |
name |
string |
Name of the peer group |
peer |
Information describing the router to peer with |
state |
string |
State of the peer group |
uuid |
string |
UUID of the peer group |
Example request
"ipspace": {
"name": "Default",
"local": {
"interface": {
"name": "lif1",
"ip": {
"address": "10.10.10.7",
"netmask": "24"
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "bgpv4peer",
"peer": {
"state": "string",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376963 |
Duplicate IP address is specified. |
1966133 |
Since masking an address with a netmask represents an entire IP subnet, the masked and unmasked IP addresses cannot be the same. |
1966267 |
IPv6 addresses must have a prefix length of 64. |
1966269 |
IPv4 addresses must have a netmask length between 1 and 32. |
1967082 |
IPspace name and UUID must match if both are given. |
1967155 |
The specified local.port.name does not match the location.port.name for the specified local.interface. |
1967156 |
The specified local.port.node.name does not match the location.port.node.name for the specified local.interface. |
1967157 |
The specified local.port.uuid does not match the location.port.uuid for the specified local.interface. |
1967158 |
The specified local.interface.name does not exist in the associated IPspace. local.ip.address and local.ip.netmask are required to create a new LIF. |
1967159 |
local.interface does not support management-bgp service. |
1967160 |
The specified local.interface.name does not match the specified interface name of local.interface.uuid. |
1967161 |
The specified local.interface.uuid does not exist in the specified IPspace. |
1967162 |
Either local.interface or local.ip and local.port are required to specify a local LIF. |
1967163 |
The specified local.port.name does not match the specified port name of local.port.uuid. |
1967164 |
The specified local.port.node.name does not match the specified node name of local.port.uuid. |
1967165 |
The specified local.port does not exist. |
1967166 |
ipspace.uuid or ipspace.name must be provided with local.interface.name together to identify a LIF. |
1967167 |
Internal error. Failed to update BGP configuration for node. Retry the command, if necessary. |
1967168 |
Internal error. Failed to create a VIP port for IPspace on node. Retry the command, if necessary. |
1967169 |
Internal error. BGP configuration changed during the operation. Retry the command, if necessary. |
1967170 |
Internal error. VIP port configuration changed during the operation. Retry the command, if necessary. |
1967171 |
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary. |
1967172 |
Peer group could not be updated because IPspace does not exist. Retry the command, if necessary. |
1967173 |
The specified local.ip.address does not match the address for the specified local.interface. |
1967174 |
The specified local.ip.netmask does not match the netmask for the specified local.interface. |
1967176 |
The specified local.interface.name does not exist in the associated IPspace. local.port.name, local.port.node.name, or local.port.uuid is required to create a new LIF. |
1967177 |
Internal error. Failed to access the local interface. Retry the command, if necessary. |
1967178 |
The IPv6 address specified with local.ip.address is not supported because it is link-local, multicast, v4-compatible, v4-mapped, loopback or "::". |
1967179 |
The IPv4 address specified with local.ip.address is not supported because it is multicast, loopback or 0.0.0.0. |
1967187 |
Configuring 4 bytes peer.asn requires an effective cluster version of 9.9.1 or later. |
1967188 |
Configuring peer address as a next hop requires an effective cluster version of 9.9.1 or later. |
1967189 |
The parameter peer.asn can't be zero. |
53281985 |
Internal error. Failed to update BGP peer group because BGP LIF moved during the operation. Wait a few minutes and try the command again. |
53282006 |
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address. |
53282007 |
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family. |
53282018 |
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip
IP information
interface
A network interface. Either UUID or name may be supplied on input.
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ip
IP information to create a new interface.
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
node
name |
string |
Name of node on which the port is located. |
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name |
string |
node |
uuid |
string |
local
interface |
A network interface. Either UUID or name may be supplied on input. |
ip |
IP information to create a new interface. |
port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
peer
address |
string |
Peer router address |
asn |
integer |
Autonomous system number of peer |
is_next_hop |
boolean |
Use peer address as next hop. |
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace |
local |
name |
string |
peer |
state |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
