REST API reference
Create a new BGP peer group for VIP
Creates a new BGP peer group for VIP, automatically enabling multipath-routing cluster-wide if it results in multiple available paths for existing or future VIP interfaces. Use this to optimize routing paths and manage network configurations effectively.
HTTP method and endpoint
POST /network/ip/bgp/peer-groups
Introduced in
ONTAP 9.7
Usage notes
Multipath-routing is turned on cluster-wide automatically if the peer group being created results in multiple paths being available for an existing or future VIP interface.
Required properties
  • name - Name of the peer-group to create.
  • ipspace.name or ipspace.uuid or local.port
    • Required with local.interface.name or local.ip.address to identify a local interface
    • Optional when local.interface.uuid is specified
  • local.interface.uuid or local.interface.name or local.ip.address
    • Required when specifying an existing local interface.
  • local.ip and local.port
    • Required to create a new local interface.
  • peer.address - IP address of the peer router
Default property values
If not specified in POST, the following default property values are assigned:
  • is_next_hop - false
  • peer.md5_enabled - false
  • network bgp peer-group create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ipspace
ipspace
Either the UUID or name is supplied on input.
local
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
name
string
Name of the peer group
peer
peer
Information describing the router to peer with
state
string
State of the peer group
uuid
string
UUID of the peer group
Example request
  "ipspace": {
    "name": "Default",
  "local": {
    "interface": {
      "name": "lif1",
    "ip": {
      "address": "10.10.10.7",
      "netmask": "24"
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "bgpv4peer",
  "peer": {
    "md5_enabled": 1,
    "md5_secret": "SECRET_WORD"
  "state": "string",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1376963
Duplicate IP address is specified.
1966133
Since masking an address with a netmask represents an entire IP subnet, the masked and unmasked IP addresses cannot be the same.
1966267
IPv6 addresses must have a prefix length of 64.
1966269
IPv4 addresses must have a netmask length between 1 and 32.
1967082
IPspace name and UUID must match if both are given.
1967155
The specified local.port.name does not match the location.port.name for the specified local.interface.
1967156
The specified local.port.node.name does not match the location.port.node.name for the specified local.interface.
1967157
The specified local.port.uuid does not match the location.port.uuid for the specified local.interface.
1967158
The specified local.interface.name does not exist in the associated IPspace. local.ip.address and local.ip.netmask are required to create a new LIF.
1967159
local.interface does not support management-bgp service.
1967160
The specified local.interface.name does not match the specified interface name of local.interface.uuid.
1967161
The specified local.interface.uuid does not exist in the specified IPspace.
1967162
Either local.interface or local.ip and local.port are required to specify a local LIF.
1967163
The specified local.port.name does not match the specified port name of local.port.uuid.
1967164
The specified local.port.node.name does not match the specified node name of local.port.uuid.
1967165
The specified local.port does not exist.
1967166
ipspace.uuid or ipspace.name must be provided with local.interface.name together to identify a LIF.
1967167
Internal error. Failed to update BGP configuration for node. Retry the command, if necessary.
1967168
Internal error. Failed to create a VIP port for IPspace on node. Retry the command, if necessary.
1967169
Internal error. BGP configuration changed during the operation. Retry the command, if necessary.
1967170
Internal error. VIP port configuration changed during the operation. Retry the command, if necessary.
1967171
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary.
1967172
Peer group could not be updated because IPspace does not exist. Retry the command, if necessary.
1967173
The specified local.ip.address does not match the address for the specified local.interface.
1967174
The specified local.ip.netmask does not match the netmask for the specified local.interface.
1967176
The specified local.interface.name does not exist in the associated IPspace. local.port.name, local.port.node.name, or local.port.uuid is required to create a new LIF.
1967177
Internal error. Failed to access the local interface. Retry the command, if necessary.
1967178
The IPv6 address specified with local.ip.address is not supported because it is link-local, multicast, v4-compatible, v4-mapped, loopback or "::".
1967179
The IPv4 address specified with local.ip.address is not supported because it is multicast, loopback or 0.0.0.0.
1967187
Configuring 4 bytes peer.asn requires an effective cluster version of 9.9.1 or later.
1967188
Configuring peer address as a next hop requires an effective cluster version of 9.9.1 or later.
1967189
The parameter peer.asn can't be zero.
1967192
Configuring peer.md5_enabled requires an effective cluster version of 9.16.1 or later.
1967193
Configuring peer.md5_enabled requires the peer.md5_secret parameter.
1967194
Configuring peer.md5_secret requires that peer.md5_enabled is set to true.
53281985
Internal error. Failed to update BGP peer group because BGP LIF moved during the operation. Wait a few minutes and try the command again.
53282006
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address.
53282007
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family.
53282018
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address.
53282021
IPsec must be enabled to use TCP MD5 in BGP sessions with a BGP peer-group.
53282024
peer.md5_secret should be 1-80 bytes.
53282025
peer.md5_secret should have an even length.
53282026
The hex format of peer.md5_secret should have only hex string starting with '0x'.
53282027
peer.md5_secret should be 1-79 characters.
53282028
peer.md5_secret supports only printable ASCII characters such as numbers, alphabets, or special characters.
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
ip
IP information
interface
A network interface. Either UUID or name may be supplied on input.
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ip
IP information to create a new interface.
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
node
name
string
Name of node on which the port is located.
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name
string
node
node
uuid
string
local
interface
interface
ip
ip
port
port
peer
address
string
Peer router address
asn
integer
Autonomous system number of peer
is_next_hop
boolean
Use peer address as next hop.
md5_enabled
boolean
Enable or disable TCP MD5 signatures per RFC 2385.
md5_secret
string
The shared TCP MD5 secret key. This can either be given as a password or hexadecimal key.
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace
ipspace
local
local
name
string
peer
peer
state
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
