REST API reference
Create an Active Directory preferred DC configuration for an SVM
Creates a preferred domain controller configuration within an SVM's Active Directory setup. Use this endpoint when you need to specify a particular DC to optimize domain-related operations for your SVM.
HTTP method and endpoint
POST /protocols/active-directory/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory preferred DC configuration for an SVM.
Required properties
  • svm.uuid - Existing SVM in which to create the preferred DC.
  • domain - Fully Qualified Domain Name.
  • server_ip - IPv4/IPv6 address of the preferred DC.
The following parameters are optional:
  • skip_config_validation
  • vserver active-directory preferred-dc add
boolean
query
False
Skip the validation of the specified preferred DC configuration.
  • Default value:
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
fqdn
string
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
Example request
  "fqdn": "test.com",
  "server_ip": "4.4.4.4"
Status: 201, Created
fqdn
string
server_ip
string
  "fqdn": "test.com",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655366
Invalid domain controller.
655506
Failed to add preferred-dc.
655918
The fully qualified domain name cannot be longer than 254 bytes.
656407
Failed to validate preferred-dc.
656408
RPC failure occured during preferred-dc config validation.
active_directory_preferred_dc
fqdn
string
server_ip
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
