REST API reference
Create an Active Directory preferred DC configuration for an SVM
Creates a preferred domain controller configuration for an SVM in Active Directory, specifying the DC's domain and IP address. Use this endpoint when you need to define or update the preferred DC settings for a storage virtual machine.
HTTP method and endpoint
POST /protocols/active-directory/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory preferred DC configuration for an SVM.
Required properties
  • svm.uuid - Existing SVM in which to create the preferred DC.
  • domain - Fully Qualified Domain Name.
  • server_ip - IPv4/IPv6 address of the preferred DC.
The following parameters are optional:
  • skip_config_validation
  • vserver active-directory preferred-dc add
boolean
query
False
Skip the validation of the specified preferred DC configuration.
  • Default value:
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
fqdn
string
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
Example request
  "fqdn": "test.com",
  "server_ip": "4.4.4.4"
Status: 201, Created
fqdn
string
server_ip
string
  "fqdn": "test.com",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655366
Invalid domain controller.
655506
Failed to add preferred-dc.
655918
The fully qualified domain name cannot be longer than 254 bytes.
656407
Failed to validate preferred-dc.
656408
RPC failure occurred during preferred-dc config validation.
active_directory_preferred_dc
fqdn
string
server_ip
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
