Create an Active Directory preferred DC configuration for an SVM
Configures an Active Directory preferred domain controller for a storage virtual machine (SVM). This setup is typically used to specify a preferred domain controller for authentication and directory services within the SVM.
HTTP method and endpoint
POST /protocols/active-directory/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory preferred DC configuration for an SVM.
Required properties
svm.uuid- Existing SVM in which to create the preferred DC. -
fqdn- Fully Qualified Domain Name. -
server_ip- IPv4/IPv6 address of the preferred DC.
The following parameters are optional:
skip_config_validation
Related ONTAP commands
vserver active-directory preferred-dc add
skip_config_validation |
boolean |
query |
False |
Skip the validation of the specified preferred DC configuration.
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
Example request
"fqdn": "test.com",
"server_ip": "4.4.4.4"
Status: 201, Created
fqdn |
string |
server_ip |
string |
"fqdn": "test.com",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655366 |
Invalid domain controller. |
655506 |
Failed to add preferred-dc. |
655918 |
The fully qualified domain name cannot be longer than 254 bytes. |
656407 |
Failed to validate preferred-dc. |
656408 |
RPC failure occurred during preferred-dc config validation. |
active_directory_preferred_dc
fqdn |
string |
server_ip |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
