Create an Active Directory preferred DC configuration for an SVM
Configures an Active Directory preferred domain controller for an SVM by specifying the domain and server IP address. This setup is useful when you want to ensure consistent authentication with a specific domain controller.
HTTP method and endpoint
POST /protocols/active-directory/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory preferred DC configuration for an SVM.
Required properties
svm.uuid- Existing SVM in which to create the preferred DC. -
domain- Fully Qualified Domain Name. -
server_ip- IPv4/IPv6 address of the preferred DC.
The following parameters are optional:
skip_config_validation
Related ONTAP commands
vserver active-directory preferred-dc add
skip_config_validation |
boolean |
query |
False |
Skip the validation of the specified preferred DC configuration.
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
Example request
"fqdn": "test.com",
"server_ip": "4.4.4.4"
Status: 201, Created
fqdn |
string |
server_ip |
string |
"fqdn": "test.com",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655366 |
Invalid domain controller. |
655506 |
Failed to add preferred-dc. |
655918 |
The fully qualified domain name cannot be longer than 254 bytes. |
656407 |
Failed to validate preferred-dc. |
656408 |
RPC failure occurred during preferred-dc config validation. |
active_directory_preferred_dc
fqdn |
string |
server_ip |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
