Create an Active Directory account for an SVM
Creates an Active Directory account for a specific SVM to integrate the SVM with an Active Directory domain. Use this operation when setting up domain authentication or when joining a domain.
HTTP method and endpoint
POST /protocols/active-directory
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory account for a given SVM.
Related ONTAP commands
vserver active-directory create
Important notes
Active Directory account creation is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
force_account_overwrite |
boolean |
If set to true and a machine account exists with the same name as specified in "name" in Active Directory, it will be overwritten and reused. |
fqdn |
string |
Fully qualified domain name. |
name |
string |
Active Directory (AD) account NetBIOS name. |
organizational_unit |
string |
Organizational unit under which the Active Directory account will be created. |
password |
string |
Administrator password required for Active Directory account creation, modification and deletion. |
svm |
username |
string |
Administrator username required for Active Directory account creation, modification and deletion. |
Example request
"force_account_overwrite": "",
"fqdn": "server1.com",
"name": "account1",
"organizational_unit": "CN=Test",
"password": "testpwd",
"svm": {
"name": "svm1",
"username": "admin"
Status: 201, Created
boolean |
fqdn |
string |
name |
string |
string |
password |
string |
svm |
username |
string |
"name": "account1",
"svm": {
"name": "svm1",
"username": "admin"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
656464 |
Failed to create the Active Directory machine account. Reason: Invalid Credentials. |
656465 |
Failed to create the Active Directory machine account. Reason: Account with same name already exists. |
656466 |
Failed to create the Active Directory machine account. Reason: Domain Controller is not reachable or does not exist. |
656467 |
Failed to create the Active Directory machine account. Reason: Organizational-Unit not found. |
href |
string |
_links
node
name |
string |
uuid |
string |
active_directory_discovered_server_reference
ip |
string |
The IP address of the server that was discovered. |
name |
string |
Server Name |
type |
string |
The type of the server that was discovered. |
discovered_servers
domain |
string |
The Active Directory domain that the discovered server is a member of. |
node |
preference |
string |
The preference level of the server that was discovered. |
server |
state |
string |
The status of the connection to the server that was discovered. |
preferred_dcs
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
active_directory
boolean |
fqdn |
string |
name |
string |
string |
password |
string |
svm |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
