Create an Active Directory account for an SVM
Creates an Active Directory account for an SVM to integrate it with your directory services, facilitating centralized authentication and management.
HTTP method and endpoint
POST /protocols/active-directory
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory account for a given SVM.
Related ONTAP commands
vserver active-directory create
Important notes
Active Directory account creation is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
discovered_servers |
array[discovered_servers] |
Specifies the discovered servers records. |
force_account_overwrite |
boolean |
If set to true and a machine account exists with the same name as specified in "name" in Active Directory, it will be overwritten and reused. |
fqdn |
string |
Fully qualified domain name. |
name |
string |
Active Directory (AD) account NetBIOS name. |
organizational_unit |
string |
Organizational unit under which the Active Directory account will be created. |
password |
string |
Administrator password required for Active Directory account creation, modification and deletion. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred domain controller (DC) records. |
security |
svm |
username |
string |
Administrator username required for Active Directory account creation, modification and deletion. |
Example request
"discovered_servers": [
"domain": "server1.com",
"node": {
"name": "node1",
"preference": "preferred",
"server": {
"ip": "7.4.3.1",
"name": "scspk0659102001",
"type": "kerberos"
"state": "ok"
"force_account_overwrite": "",
"fqdn": "server1.com",
"name": "account1",
"organizational_unit": "CN=Test",
"password": "testpwd",
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4"
"security": {
"advertised_kdc_encryptions": [
"string"
"svm": {
"name": "svm1",
"username": "admin"
Status: 201, Created
boolean |
fqdn |
string |
name |
string |
string |
password |
string |
preferred_dcs |
security |
svm |
username |
string |
"node": {
"name": "node1",
"server": {
"ip": "7.4.3.1",
"type": "kerberos"
"state": "ok"
"name": "account1",
"preferred_dcs": [
"fqdn": "test.com",
"security": {
"string"
"svm": {
"name": "svm1",
"username": "admin"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655562 |
The NetBIOS name cannot be longer than 15 characters. |
655915 |
A CIFS server for this SVM already exists. Having both a CIFS server and an Active Directory account for the same SVM is not supported. Use the \"vserver cifs delete\" command to delete the existing CIFS server and try the command again. |
656464 |
Failed to create the Active Directory machine account. Reason: Invalid Credentials. |
656465 |
Failed to create the Active Directory machine account. Reason: An account with this name already exists. |
656466 |
Failed to create the Active Directory machine account. Reason: Unable to connect to any domain controllers. |
656467 |
Failed to create the Active Directory machine account. Reason: Organizational-Unit not found. |
656490 |
Unable to create the Active Directory account. The Active Directory account name is already used by another SVM. |
656491 |
Failed to create the Active Directory machine account. Reason: This operation is supported only on data SVMs. |
656494 |
The Active Directory was created but was not fully configured. |
656495 |
Failed to update Active Directory security settings for SVM. |
656496 |
Failed to update Active Directory security settings for SVM. Reason: KDC has no support for encryption type. |
href |
string |
_links
node
name |
string |
uuid |
string |
active_directory_discovered_server_reference
ip |
string |
The IP address of the server that was discovered. |
name |
string |
Server Name |
type |
string |
The type of the server that was discovered. |
discovered_servers
domain |
string |
The Active Directory domain that the discovered server is a member of. |
node |
preference |
string |
The preference level of the server that was discovered. |
server |
state |
string |
The status of the connection to the server that was discovered. |
preferred_dcs
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address. |
active_directory_security
advertised_kdc_encryptions |
array[string] |
svm
name |
string |
uuid |
string |
active_directory
boolean |
fqdn |
string |
name |
string |
string |
password |
string |
preferred_dcs |
security |
svm |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
