REST API reference
Create an Active Directory account for an SVM
Creates an Active Directory account for a specific SVM to integrate the SVM with your organization's Active Directory service. Use this operation when setting up domain services for your storage virtual machine.
HTTP method and endpoint
POST /protocols/active-directory
Introduced in
ONTAP 9.12
Usage notes
Creates an Active Directory account for a given SVM.
  • vserver active-directory create
Important notes
  • Active Directory account creation is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
force_account_overwrite
boolean
If set to true and a machine account exists with the same name as specified in "name" in Active Directory, it will be overwritten and reused.
fqdn
string
Fully qualified domain name.
name
string
Active Directory (AD) account NetBIOS name.
organizational_unit
string
Organizational unit under which the Active Directory account will be created.
password
string
Administrator password required for Active Directory account creation, modification and deletion.
svm
svm
username
string
Administrator username required for Active Directory account creation, modification and deletion.
Example request
  "force_account_overwrite": "",
  "fqdn": "server1.com",
  "name": "account1",
  "organizational_unit": "CN=Test",
  "password": "testpwd",
  "svm": {
    "name": "svm1",
  "username": "admin"
Status: 201, Created
boolean
fqdn
string
name
string
organizational_unit
string
password
string
svm
svm
username
string
  "name": "account1",
  "svm": {
    "name": "svm1",
  "username": "admin"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
656464
Failed to create the Active Directory machine account. Reason: Invalid Credentials.
656465
Failed to create the Active Directory machine account. Reason: Account with same name already exists.
656466
Failed to create the Active Directory machine account. Reason: Domain Controller is not reachable or does not exist.
656467
Failed to create the Active Directory machine account. Reason: Organizational-Unit not found.
string
node
name
string
uuid
string
active_directory_discovered_server_reference
ip
string
The IP address of the server that was discovered.
name
string
Server Name
type
string
The type of the server that was discovered.
discovered_servers
domain
string
The Active Directory domain that the discovered server is a member of.
node
node
preference
string
The preference level of the server that was discovered.
server
state
string
The status of the connection to the server that was discovered.
preferred_dcs
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
active_directory
boolean
fqdn
string
name
string
organizational_unit
string
password
string
svm
svm
username
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
