REST API reference
Create an Active Directory account for an SVM
POST /protocols/active-directory
Introduced In: 9.12
Creates an Active Directory account for a given SVM.
  • vserver active-directory create
Important notes
  • Active Directory account creation is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
force_account_overwrite
boolean
If set to true and a machine account exists with the same name as specified in "name" in Active Directory, it will be overwritten and reused.
fqdn
string
Fully qualified domain name.
name
string
Active Directory (AD) account NetBIOS name.
organizational_unit
string
Organizational unit under which the Active Directory account will be created.
password
string
Administrator password required for Active Directory account creation, modification and deletion.
preferred_dcs
array[preferred_dcs]
Specifies the preferred domain controller (DC) records.
security
active_directory_security
svm
svm
username
string
Administrator username required for Active Directory account creation, modification and deletion.
Example request
  "discovered_servers": [
      "domain": "server1.com",
      "node": {
        "name": "node1",
      "preference": "preferred",
      "server": {
        "ip": "7.4.3.1",
        "name": "scspk0659102001",
        "type": "kerberos"
      "state": "ok"
  "force_account_overwrite": "",
  "fqdn": "server1.com",
  "name": "account1",
  "organizational_unit": "CN=Test",
  "password": "testpwd",
  "preferred_dcs": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
  "security": {
    "advertised_kdc_encryptions": [
      "string"
  "svm": {
    "name": "svm1",
  "username": "admin"
Status: 201, Created
discovered_servers
boolean
fqdn
string
name
string
organizational_unit
string
password
string
preferred_dcs
security
svm
svm
username
string
      "node": {
        "name": "node1",
      "server": {
        "ip": "7.4.3.1",
        "type": "kerberos"
      "state": "ok"
  "name": "account1",
  "preferred_dcs": [
      "fqdn": "test.com",
  "security": {
      "string"
  "svm": {
    "name": "svm1",
  "username": "admin"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655562
The NetBIOS name cannot be longer than 15 characters.
655915
A CIFS server for this SVM already exists. Having both a CIFS server and an Active Directory account for the same SVM is not supported. Use the \"vserver cifs delete\" command to delete the existing CIFS server and try the command again.
656464
Failed to create the Active Directory machine account. Reason: Invalid Credentials.
656465
Failed to create the Active Directory machine account. Reason: An account with this name already exists.
656466
Failed to create the Active Directory machine account. Reason: Unable to connect to any domain controllers.
656467
Failed to create the Active Directory machine account. Reason: Organizational-Unit not found.
656490
Unable to create the Active Directory account. The Active Directory account name is already used by another SVM.
656491
Failed to create the Active Directory machine account. Reason: This operation is supported only on data SVMs.
656494
The Active Directory was created but was not fully configured.
656495
Failed to update Active Directory security settings for SVM.
656496
Failed to update Active Directory security settings for SVM. Reason: KDC has no support for encryption type.
string
node
name
string
uuid
string
active_directory_discovered_server_reference
ip
string
The IP address of the server that was discovered.
name
string
Server Name
type
string
The type of the server that was discovered.
discovered_servers
domain
string
The Active Directory domain that the discovered server is a member of.
node
node
preference
string
The preference level of the server that was discovered.
server
state
string
The status of the connection to the server that was discovered.
preferred_dcs
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred DC. The address can be either an IPv4 or an IPv6 address.
array[string]
svm
name
string
uuid
string
active_directory
discovered_servers
boolean
fqdn
string
name
string
organizational_unit
string
password
string
preferred_dcs
security
svm
svm
username
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
