Re-key or re-version an AWS KMS key encryption key for AWS KMS
Res-key or re-version an AWS KMS Key Encryption Key (KEK) for your AWS KMS, updating the encryption key to maintain security compliance or adapt to new encryption standards.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-external
Introduced in
ONTAP 9.12
Usage notes
Rekeys or re-versions the AWS KMS Key Encryption Key (KEK) for the given AWS KMS.
Related ONTAP commands
security key-manager external aws rekey-external
aws_kms.uuid |
string |
path |
True |
UUID of the existing AWS KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier of the AWS KMS key encryption key. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
Example request
"key_id": "key01",
"scope": "string",
"svm": {
"name": "svm1",
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537538 |
Internal error. Failed to get unwrapped key for a given key ID. |
65537543 |
Internal Error. Missing top-level internal key protection key (KEK) on a node. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager before running the rekey operation. |
65537919 |
External rekey failed on one or more nodes. |
65537926 |
AWS KMS is not configured for the given SVM. |
href |
string |
_links
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
aws_kms_key
key_id |
string |
scope |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
