Re-key or re-version an AWS KMS key encryption key for AWS KMS
Rekeys or re-versions the AWS KMS Key Encryption Key (KEK) to manage encryption key lifecycles and enhance security for your AWS KMS.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-external
Introduced in
ONTAP 9.12
Usage notes
Rekeys or re-versions the AWS KMS Key Encryption Key (KEK) for the given AWS KMS.
Related ONTAP commands
security key-manager external aws rekey-external
aws_kms.uuid |
string |
path |
True |
UUID of the existing AWS KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier of the AWS KMS key encryption key. |
Example request
"key_id": "key01"
Status: 202, Accepted
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537538 |
Internal error. Failed to get unwrapped key for a given key ID. |
65537543 |
Internal Error. Missing top-level internal key protection key (KEK) on a node. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager before running the rekey operation. |
65537919 |
External rekey failed on one or more nodes. |
65537926 |
AWS KMS is not configured for the given SVM. |
aws_kms_key
key_id |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
