Re-key or re-version an AWS KMS key encryption key for AWS KMS
Rekeys or re-version an AWS KMS Key Encryption Key (KEK) to update the encryption configuration for your AWS KMS resources.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-external
Introduced in
ONTAP 9.12
Usage notes
Rekeys or re-versions the AWS KMS Key Encryption Key (KEK) for the given AWS KMS.
Related ONTAP commands
security key-manager external aws rekey-external
aws_kms.uuid |
string |
path |
True |
UUID of the existing AWS KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key_id |
string |
Key identifier of the AWS KMS key encryption key. |
Example request
"key_id": "key01"
Status: 202, Accepted
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537538 |
Internal error. Failed to get unwrapped key for a given key ID. |
65537543 |
Internal Error. Missing top-level internal key protection key (KEK) on a node. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager before running the rekey operation. |
65537610 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent rekeying for the SVM. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation. |
65537919 |
External rekey failed on one or more nodes. |
65537926 |
AWS KMS is not configured for the given SVM. |
65539436 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being initialized. Wait until the keystore is in the active state, and rerun the rekey operation. |
65539437 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being disabled. |
aws_kms_key
key_id |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
