REST API reference
Re-key or re-version an AWS KMS key encryption key for AWS KMS
Re-keys or re-versions an AWS KMS key encryption key to update encryption settings and enhance security management in AWS KMS.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/rekey-external
Introduced in
ONTAP 9.12
Usage notes
Rekeys or re-versions the AWS KMS Key Encryption Key (KEK) for the given AWS KMS.
  • security key-manager external aws rekey-external
aws_kms.uuid
string
path
True
UUID of the existing AWS KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key_id
string
Key identifier of the AWS KMS key encryption key.
Example request
  "key_id": "key01"
Status: 202, Accepted
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65537538
Internal error. Failed to get unwrapped key for a given key ID.
65537543
Internal Error. Missing top-level internal key protection key (KEK) on a node.
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager before running the rekey operation.
65537919
External rekey failed on one or more nodes.
65537926
AWS KMS is not configured for the given SVM.
aws_kms_key
key_id
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
