REST API reference
Delete SMB session information for an SVM node
Deletes SMB session information on a node for a specific storage virtual machine (SVM). Use this operation to manage and clear SMB sessions as needed for maintaining or troubleshooting SVM node activities.
HTTP method and endpoint
DELETE /protocols/cifs/sessions/{node.uuid}/{svm.uuid}/{identifier}/{connection_id}
Introduced in
ONTAP 9.9
Usage notes
Deletes SMB session information on a node for an SVM.
  • To delete the specific SMB session information, pass the relavant SMB session's identifier and connection Id.
  • To delete all the SMB session information on specific node and SVM, pass the both SMB session's identifier and connection Id as zero(0)
  • To delete all the SMB session information on specific connection, pass the specific SMB session's Identifier value as zero(0).
  • To delete all the SMB session information on specific Identifier alone is not allowed.
node.uuid
string
path
True
Node UUID.
identifier
integer
path
True
Unique identifier for the SMB session.
connection_id
integer
path
True
Unique identifier for the SMB connection.
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655503
The SMB session delete does not allow a connection ID of zero (0).
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
