REST API reference
Delete SMB session information for an SVM node
Deletes SMB session information for an SVM node, managing active SMB connections and sessions effectively. Use this endpoint when you need to terminate specific SMB sessions or clear all sessions for maintenance or troubleshooting purposes.
HTTP method and endpoint
DELETE /protocols/cifs/sessions/{node.uuid}/{svm.uuid}/{identifier}/{connection_id}
Introduced in
ONTAP 9.9
Usage notes
Deletes SMB session information on a node for an SVM.
  • To delete the specific SMB session information, pass the relavant SMB session's identifier and connection Id.
  • To delete all the SMB session information on specific node and SVM, pass the both SMB session's identifier and connection Id as zero(0)
  • To delete all the SMB session information on specific connection, pass the specific SMB session's Identifier value as zero(0).
  • To delete all the SMB session information on specific Identifier alone is not allowed.
  • vserver cifs session close
node.uuid
string
path
True
Node UUID.
identifier
integer
path
True
Unique identifier for the SMB session.
connection_id
integer
path
True
Unique identifier for the SMB connection.
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655503
The SMB session delete does not allow a connection ID of zero (0).
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
