Delete SMB session information for an SVM node
DELETE /protocols/cifs/sessions/{node.uuid}/{svm.uuid}/{identifier}/{connection_id}
Introduced In: 9.9
Deletes SMB session information on a node for an SVM.
To delete the specific SMB session information, pass the relavant SMB session's identifier and connection Id.
To delete all the SMB session information on specific connection, pass the specific SMB session's Identifier value as zero(0).
To delete all the SMB session information, pass the specific session's identifier and connection Id values as zero(0).
To delete all the SMB session information on specific Identifier alone is not allowed.
Learn more
node.uuid |
string |
path |
True |
Node UUID. |
identifier |
integer |
path |
True |
Unique identifier for the SMB session. |
connection_id |
integer |
path |
True |
Unique identifier for the SMB connection. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655503 |
The SMB session delete does not allow a connection ID of zero (0). |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
