Delete SMB session information for an SVM node
DELETE /protocols/cifs/sessions/{node.uuid}/{svm.uuid}/{identifier}/{connection_id}
Introduced In: 9.9
Deletes SMB session information on a node for an SVM.
To delete the specific SMB session information, pass the relevant SMB session's identifier and connection Id.
To delete all the SMB session information on specific node and SVM, pass the both SMB session's identifier and connection Id as zero(0)
To delete all the SMB session information on specific connection, pass the specific SMB session's Identifier value as zero(0).
To delete all the SMB session information on specific Identifier alone is not allowed.
Related ONTAP commands
vserver cifs session close
Learn more
node.uuid  |
string  |
path  |
True  |
Node UUID.  |
identifier  |
integer  |
path  |
True  |
Unique identifier for the SMB session.  |
connection_id  |
integer  |
path  |
True  |
Unique identifier for the SMB connection.  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655503  |
The SMB session delete does not allow a connection ID of zero (0).  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
