REST API reference
Delete an SAML service provider configuration
Deletes a SAML service provider configuration when you need to remove its integration with your system.
HTTP method and endpoint
DELETE /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
12320803
SAML must be disabled before the configuration can be removed.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
