REST API reference
Delete an SAML service provider configuration
Deletes a SAML service provider configuration, removing its integration settings from your system. Use this endpoint when you need to discontinue service provider relationships or update authentication methods.
HTTP method and endpoint
DELETE /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
12320803
SAML must be disabled before the configuration can be removed.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
