Delete an SAML service provider configuration
Removes an SAML service provider configuration from your system when it is no longer needed, ensuring your configurations remain current and relevant.
HTTP method and endpoint
DELETE /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Usage notes
Deletes a SAML service provider configuration.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320803 |
SAML must be disabled before the configuration can be removed. |
12320832 |
Internal Error. Failed to execute the command, web server setup is in progress. Retry after some time. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
