REST API reference
Delete an SAML service provider configuration
Removes an SAML service provider configuration from your system when it is no longer needed, ensuring your configurations remain current and relevant.
HTTP method and endpoint
DELETE /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Usage notes
Deletes a SAML service provider configuration.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
12320803
SAML must be disabled before the configuration can be removed.
12320832
Internal Error. Failed to execute the command, web server setup is in progress. Retry after some time.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
