REST API reference
Cancel an ongoing EBR operation
Aborts an ongoing EBR operation when you need to halt its progress, typically to prevent unintended changes or outcomes in your storage environment.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/operations/{id}
Introduced in
ONTAP 9.7
  • snaplock event-retention abort
id
string
path
True
Unique identifier of an EBR operation
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090541
A completed or failed operation cannot be aborted
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
