REST API reference
Cancel an ongoing EBR operation
Stops an ongoing EBR operation when you need to abort the process before completion.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Aborts an ongoing EBR operation.
  • snaplock event-retention abort
id
string
path
True
Unique identifier of an EBR operation
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090541
A completed or failed operation cannot be aborted
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
