REST API reference
Cancel an ongoing EBR operation
Cancels an ongoing EBR operation to terminate the process before it completes. This is useful when you need to stop an operation that is no longer required or is causing issues.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Aborts an ongoing EBR operation.
  • snaplock event-retention abort
id
string
path
True
Unique identifier of an EBR operation
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090541
A completed or failed operation cannot be aborted
14090242
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
