Cancel an ongoing EBR operation
Cancels an ongoing EBR operation to terminate the process before it completes. This is useful when you need to stop an operation that is no longer required or is causing issues.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Aborts an ongoing EBR operation.
Related ONTAP commands
snaplock event-retention abort
id |
string |
path |
True |
Unique identifier of an EBR operation |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090541 |
A completed or failed operation cannot be aborted |
14090242 |
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
