Delete unexpired WORM files of a SnapLock enterprise volume
Performs a privileged delete of unexpired WORM files on a SnapLock Enterprise volume. This operation is typically used when you need to remove specific files that are otherwise protected by WORM retention policies.
HTTP method and endpoint
DELETE /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Deletes unexpired WORM files of a SnapLock Enterprise volume. This is a privileged-delete operation. The only built-in role that has access to the command is vsadmin-snaplock.
Related ONTAP commands
volume file privileged-delete
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090347 |
File path must be in the format "/ |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
