Delete unexpired WORM files of a SnapLock enterprise volume
Deletes unexpired WORM files from a SnapLock Enterprise volume using this privileged-delete operation. This endpoint is useful for managing compliance data that still resides within its retention period.
HTTP method and endpoint
DELETE /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Deletes unexpired WORM files of a SnapLock Enterprise volume. This is a privileged-delete operation. The only built-in role that has access to the command is vsadmin-snaplock.
Related ONTAP commands
volume file privileged-delete
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
| Error code | Description |
262179 |
Unexpected argument " |
6691623 |
User is not authorized |
13763162 |
SnapLock audit log volume is not configured for the SVM |
13763280 |
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation |
14090347 |
File path must be in the format "\/<dir>\/<file path>" |
917804 |
Path should be given in the format "\/\vol\/<volume name>\/<file path>". |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
