REST API reference
Delete unexpired WORM files of a SnapLock enterprise volume
Deletes unexpired WORM files from a SnapLock Enterprise volume using this privileged-delete operation. This endpoint is useful for managing compliance data that still resides within its retention period.
HTTP method and endpoint
DELETE /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Deletes unexpired WORM files of a SnapLock Enterprise volume. This is a privileged-delete operation. The only built-in role that has access to the command is vsadmin-snaplock.
  • volume file privileged-delete
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
Error code Description
262179
Unexpected argument "\"
6691623
User is not authorized
13763162
SnapLock audit log volume is not configured for the SVM
13763280
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation
14090347
File path must be in the format "\/<dir>\/<file path>"
917804
Path should be given in the format "\/\vol\/<volume name>\/<file path>".
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
