Delete unexpired WORM files of a SnapLock enterprise volume
Deletes unexpired WORM files from a SnapLock Enterprise volume to manage file retention and ensure compliance with data governance policies.
HTTP method and endpoint
DELETE /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Deletes unexpired WORM files of a SnapLock Enterprise volume. This is a privileged-delete operation. The only built-in role that has access to the command is vsadmin-snaplock.
Related ONTAP commands
volume file privileged-delete
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
| Error code |
Description |
262179 |
Unexpected argument " |
//end row //start row |
6691623 //end row //start row |
User is not authorized //end row //start row |
13763162 //end row //start row |
SnapLock audit log volume is not configured for the SVM //end row //start row |
13763280 //end row //start row |
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation //end row //start row |
14090347 //end row //start row |
File path must be in the format "/ |
917804 //end row //start row |
Path should be given in the format "/vol/ |
=== //end table [cols=3*,options=header] |
|Name |Type |Description
|error |returned_error a|
.Example error [%collapsible%closed] ==== [source,json,subs=+macros] { "error": { "arguments": [ { "code": "string", "message": "string" } ], "code": "4", "message": "entry doesn't exist", "target": "uuid" } } ==== == Definitions [.api-def-first-level] .See Definitions [%collapsible%closed] ==== [#href] [.api-collapsible-fifth-title] href [cols=3*,options=header] |
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [cols=3*,options=header] |
|self |href a|
[#job_link] [.api-collapsible-fifth-title] job_link [cols=3*,options=header] |
|_links |_links a|
|uuid |string a|The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
[#error_arguments] [.api-collapsible-fifth-title] error_arguments [cols=3*,options=header] |
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error [cols=3*,options=header] |
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
