REST API reference
Retrieves the results of a completed diagnostic operation for the metrocluster configuration
GET /cluster/metrocluster/diagnostics
Introduced In: 9.8
Retrieves the results of a completed diagnostic operation for the MetroCluster configuration.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
Status: 200, Ok
Name Type Description
aggregate
aggregate
cluster
cluster
config-replication
config-replication
connection
connection
interface
interface
node
node
volume
volume
  "aggregate": {
    "details": [
        "aggregate": {
              "href": "/api/resourcelink"
          "name": "aggr1",
        "checks": [
            "additional_info": {
              "code": "string",
              "message": "string"
            "name": "mirrror_status",
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "timestamp": "2016-03-10 22:35:16 +0000",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "cluster": {
    "details": [
        "aggregate": {
          "name": "aggr1",
        "checks": [
              "code": "string",
              "message": "string"
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "config-replication": {
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
    "timestamp": "2016-03-14 22:35:16 +0000"
  "connection": {
    "details": [
        "cluster": {
          "name": "cluster1",
        "connections": [
            "destination_address": "string",
            "partner": {
              "node": {
                "name": "node1",
              "type": "string"
            "port": "string",
            "result": "string",
            "source_address": "string",
            "state": "string"
        "node": {
          "name": "node1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "interface": {
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "node": {
    "details": [
        "aggregate": {
          "name": "aggr1",
        "checks": [
              "code": "string",
              "message": "string"
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
  "volume": {
    "details": [
        "aggregate": {
          "name": "aggr1",
        "checks": [
              "code": "string",
              "message": "string"
            "result": "string"
        "cluster": {
          "name": "cluster1",
        "node": {
          "name": "node1",
        "volume": {
          "name": "volume1",
    "state": "string",
    "summary": {
      "code": "string",
      "message": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427132
MetroCluster is not configured on this cluster.
2432856
MetroCluster diagnostics result is not available. Use the REST API GET method on "/api/cluster/metrocluster/operations?type=check&fields=*" for more information.
string
self
aggregate
_links
_links
name
string
uuid
string
additional_info
Additional information or recovery steps to take on this component.
code
string
Argument code
message
string
Message argument
metrocluster_diag_check
Generic object which can be used for various components which holds details of the checks of a component.
additional_info
additional_info
name
string
Name of type of diagnostic operation run for the component.
result
string
Result of the diagnostic operation on this component.
cluster
_links
_links
name
string
uuid
string
node
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
metrocluster_diag_details
aggregate
aggregate
checks
array[metrocluster_diag_check]
Collection of MetroCluster checks done for component.
cluster
cluster
node
node
timestamp
string
Time check was done.
volume
volume
summary
Additional information or recovery steps to take.
code
string
Argument code
message
string
Message argument
aggregate
details
array[metrocluster_diag_details]
Display details of the MetroCluster check for aggregates.
state
string
Status of diagnostic operation for this component.
summary
summary
timestamp
string
Time of the most recent diagnostic operation for this component
cluster
details
Display details of the MetroCluster check for clusters.
state
string
summary
summary
timestamp
string
config-replication
state
string
summary
summary
timestamp
string
partner
node
node
type
string
metrocluster_diag_connection
destination_address
string
partner
partner
port
string
result
string
source_address
string
state
string
metrocluster_diag_connection_details
cluster
cluster
connections
array[metrocluster_diag_connection]
node
node
connection
details
array[metrocluster_diag_connection_details]
Display details of the MetroCluster check for connections.
state
string
summary
summary
timestamp
string
interface
state
string
summary
summary
timestamp
string
node
details
Displays details of the MetroCluster check for nodes.
state
string
summary
summary
timestamp
string
volume
details
Display details of the MetroCluster check for volumes.
state
string
summary
summary
timestamp
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
